I need to replace the head gasket in my 270K B27. I have all the parts, the new bolts and the bentley. I just am looking for a reality check on the torque for the head itself. Bentley states that it starts at 22lt/lbs, and second stage is +90 degrees (i can deal with this) I am just checking that 3rd stage is also correct at another +90 degrees. It is also NOT stated whether this final torque is done at room temp, or at operating temp.
This isnt a job that one wants to do over again, so I am looking for a reality check on it to make sure that my understanding is indeed correct at the torque values stated, and that I should do the final torque at room temp (much easier than doing it hot, as I dont have to contend with needing another valve cover gasket)
