edit: thread title should be "M20 Running Like Crap"
Yes, I searched.
This problem just appeared overnight about a week ago, it didn't happen gradually.
When cold, the car starts right up and runs great. As the engine warms up, it runs rougher and rougher and once it's up to normal temp it runs like crap, like it's missing a cylinder or two. However this is only under load (accelerating), and only when hot. Once I'm up to speed, if I let up on the accelerator the engine smooths out and runs like normal. If I give it more gas it runs horrible again.
I suspected a vacuum leak, but I've checked the main areas and can't find anything.
Any ideas?
BTW I did the timing belt a couple months ago, and at the same time replaced the spark plugs, distributor cap and rotor, cam seal, water pump, and did a valve adjustment.
Thanks,
I'm tired of it sounding like a lawnmower.
Yes, I searched.
Any ideas?
Thanks,
Oh babay babay
