So about 500 miles ago i replaced my clutch with a clutch masters stage 2 clutch with a jb racing aluminum flywheel. I am just wondering how i can change the spot where the clutch bites at. It bites really late on the pedal and id like to get it to bit lower on the pedal. any help?
clutch help
Tags: None
im pritty sure someone here can help you. but if not. just get a clutch stop. or fab one up yourselfSo about 500 miles ago i replaced my clutch with a clutch masters stage 2 clutch with a jb racing aluminum flywheel. I am just wondering how i can change the spot where the clutch bites at. It bites really late on the pedal and id like to get it to bit lower on the pedal. any help?] -
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
There is a small amount of adjustment of the rest position of clutch pedal, but that is the only adjustment available . The engage/disengage point is determined by the pressure plate and clutch disk. That said, spacing the slave cylinder out a bit from the bell housing will lower the engage/disengage point.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
What should i use to space out the slave cylinder? i know before i replaced my whole clutch the grab point was in the same location.There is a small amount of adjustment of the rest position of clutch pedal, but that is the only adjustment available . The engage/disengage point is determined by the pressure plate and clutch disk. That said, spacing the slave cylinder out a bit from the bell housing will lower the engage/disengage point.
