So i've been dealing with this idle issue for about a year now and i've been narrowing down things and slowly making the car run better. It is an '89 325i and has very low miles. It first started with the high idle which was fixed after replacing the tps. During that process, I replaced the AFM, o2 sensor, and fixed vacuum leaks. Recently after fixing that, I was left with a rich fuel mixture that has me pulling my hair out. So on to what has happened today, after fixing the ground that I broke off (the one on top of the passenger strut housing, next to the coil.) I started her up and she idled as usual. Really low and really rich with terrible throttle response. I unplug the ICV and notice it doesn't really affect it. After plugging it back in a unplug the AFM, and all of a sudden it seems to be idling perfectly at a seemingly stoich mixture. I rev the engine and the throttle response is better than ever! After it settles, I plug the AFM back in and its back to its rich and low idle state :(. So I unplug the ICV another time and still not much difference, and i unplug the AFM at the same time if I remember correctly and the idle shoots up to 2k until i plug the ICV back in and it settle somewhat. Then i plug the AFM back in and its back to the normal shitty state. I decide to take it for a spin and as i get to the bottom of my driveway the throttle response gets worse and suddenly the idle shoots up to 2k. I get out and take a look under the hood and wanted to see what was causing it, so i unplug the ICV and nothing happens, and then i unplug the AFM and the car sputters and dies. I tried starting it like that and it starts but doesn't hold an idle. I then plug it all back up and try to start it and it does not even catch a little bit. So now I'm stuck at square one trying to get this damn thing to work correctly!! Sometimes I really hate my car. /rant
But does anybody have the slightest clue as to what is going on with my car?? Any help is appreciated! Thanks!
