i just did an engine swap on my m20. i took the starter off the old block and put it on the new one. it was working when i took it off and i know i didnt drop it to my knowledge. Anyway went to start it up and all i get is a ticking in the starter. is there anything i can to besides take it all off and if i do what is the easiest way to remove a starter. thanks
starter
Tags: None
make sure all the connections are tight, a 'clicking' starter usually means not enough amps are getting from the batt to the starter.1991 E30 M3 Brilliant/black - S54B32/5M
1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
2011 E82 1M VO/blk/6M
1991 E31 850i red/grey/6M
1997 F355 spider red/tan/6M -
ill double check how tight they are but i have already tried 2 batteriesComment
