So i have the stroker out of the car on an engine stand. Before when i was driving it i was experiencing what i believe was pinging on throttle >1/2 in mid rpm range (was running on motronic). I would like to check over the engine as much as i can before i put it back in a car and MS it. Where should i start?
I was thinking:
Pull head to check chambers/pistons for any signs of problems
pull oil pan to check bearings
my questions,
-if i pull the head do i 100% need to get it surfaced?
-to check the bearings for excessive wear would i need to remove them or would a good visual inspection suffice?
-anything else to check?
-should i even do this?
all the obvious parts to change are already being changed.
edit: about the pinging, if you lay into the throttle more than half way you would hear it up till about 4k rpm then it would go away (obviously i avoided doing this as much as possible). i always ran 93 in this engine, cooling system works fine never above 1/4 mark. compression is 10.3:1.
I was thinking:
my questions,
