So my (10/88 325is motronic 1.1) car runs rich, very rich, when the coolant is cold. The engine stalls, sputters, shakes like a bitch until it warms up a bit.
During warm up the idle speed is low and it will hunt up and down as i come to a stop and drive off again. As the engine warms up these symptoms improve. Once fully warmed the car will idle smooth and steady and generally run fine.
Ambient temperature does seem to play a factor generally the warmer it is outside the better. Yesterday was cold and wet and she stranded me.
Intake leak? I'm sure everything the sealed on the intake itself. It could be a small leak from the oil return tube, or a crank seal, but it will idle smooth as butter when its warm.
The ICV, FPR, fuel pump, CLT sensor and AFM and CPS are all good/recently replaced.
I had a small leak on the fuel return line, and thought maybe it was plugged, but I replaced the hoses from the rail and the FPR and they were clear...
sorry for the long post, I'm stumped. What do you guys think?
