bog and gulp on blips, moisture and steam out of exhaust...
  • kronus
    • Apr 2008
    • 13032
    I'm guessing it's running very rich? Ideas on what causes that? O2 sensor?
    cars beep boop
  • strad
    • Jan 2007
    • 241
    steam out of exhaust is a judgement call. Under the conditions you are seeing steam, do you also see steam from other cars? If not, then you probably have a problem. Are you losing coolant? If you are, coupled with steam, you need to investigate for a blown head gasket.
    Under a no-signal condition from the 02 sensor, the dme will run a rich mixture to avoid detonation, but, a no signal condition from the sensor typically will turn on the check engine light. Is yours on?
    Bogging can also be caused by a clogged fuel filter. When was the last time it was changed? I've also seen bogging happen on my M30 with a sticky AFM (only happens during cold weather on mine). edit: an injector stuck open or a faulty fpr could also cause it to run rich, or poor spark.
    The current fleet:
    1992 325ic: 148k-171k miles
    1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
    1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
