Valve Lapping
  • CrazyJew89
    • Oct 2009
    • 347
    Valve Lapping
    I pulled head off to replace a rocker arm and I am planning on doing some valve lapping on my valves before I re-install the head. I know there is plenty of info and tutorials about valve lapping that you can find using google, but I was wondering if there is anything different or special that I should know about valve lapping an M20 head (couldn't find anything in the DIY section or the Bentley). Also does anyone know which compound/grit I should use?
    Thanks,
    -Ben
    '87 5-speed 325is
    The best $750 I ever spent!
    Are you in Michigan?
    Do you want to know where all the E30's are?
    Try checking out the Michigan E30 Map
