Okay, so after spending two and a half hours cleaning my car, I get ready to go for a ride, but my car does not want to run.
See, every now and then I'll start it and the battery, brake lining and anti-lock lights will be lit right on start-up and it'll run; however, it acts like it has low voltage. I simply blip the throttle to 1K and it goes away and runs fine.
This time when I started my car it didn't really want to run at all. When it did it acted like it had a broken rocker arm, to which I was like holy shit! In any case, it was making some horrible noise (think knocking) and was shaking. It was scary.
I immediately turn it off and then tried to start again, but alas it had the same issue. I revved really quick to see if that might solve it, as in the case with the lights issue mentioned earlier.
After trying again for the fifth time, it finally sorted itself out. I gave it a little gas and it seemed to catch up to itself. Then it was running fine. Ran great this morning, too.
Would this be a voltage issue? I know I need an O2 sensor soon; however, perhaps this was a CPS issue? None of the spark plug wires were loose, either. Perhaps I have some clogged injectors? I did notice a heavy fuel smell, though, so I don't think that was the problem. Distributor, rotor and other ignition components are less than a year old.
I was just glad it wasn't a rocker arm!
