Symptoms of bad plug wires?
  • bryant.cw
    • 209
    I have searched, but can't dig up much of anything useful.
    What are the symptoms of bad plug wires?
    My shit heap vert is in good shape, sensors good, all dealer maintenance, one owner etc. Mark D chip, new injectors, rebuilt head (reputable guy), new belts , timing belt done etc etc. I have checked for vacuum leaks and it is good. I call it a shit heap because it just never has run quite right. It takes too long to start, occasionally no starts, only to fire right up on the next try.
    I can hear it running on 4-5 cylinders occasionally. When it is wet out, or has rained overnight it runs on 4-5 much more often, and feels sluggish for maybe 20 minutes until warmed up. It seems like it is stumbling when it is idling. Makes me hate the car.
    Kinda at wits end.
    Side note, duralast is $91, bosch is like $160. Any difference? The duralast includes all leads including the sensor.
    Aged plug wires cause misfires and they will be sensitive moisture. Replace the wires and the distributor rotor and cap.
    But I doubt that the wires are the cause of the hard starting.
    Idle or hard starting problems are most commonly caused by intake leaks and/or
    a sticky or defective Idle Control Valve (ICV). The only reliable method of
    locating intake leaks is to have a smoke test run on the intake and crank case
    and to test the brake booster with a gage and vacuum pump. The complete list
    of possible causes of an intake leak is:
    Intake boot
    Throttle body gasket
    ICV hoses & connections
    Brake booster, hoses, and connections
    Crank case breather hose
    Evaporative control hose and valve
    Fuel pressure regulator & hose
    Injector seals
    Valve cover gaskets & bungs
    Oil filler cap
    Dip stick o-rings
    Oil return tube o-rings
    While leaks in some of those can be found by inspection or by spraying carb
    cleaner on suspect areas, not finding leaks that way doesn't eliminate the
    possibility. Only a smoke test will really work.
    Once the possibility of intake leaks is eliminated, the ICV needs to be
    removed and cleaned with carb cleaner until the vane inside moves freely. When
    the ignition is switched on you should be able to feel vibration from the
    ICV. If no vibration the ICV is bad, there's a problem with its wiring or
    connector, there's a problem with the TPS, or the DME (or Idle Control Module
    (ICM) on an ETA car) is faulty.
    For the DME (or ICM) to control idle, the idle switch in the TPS must work
    correctly. The switch should close when the throttle stop is 0.020-0.060" off
    the idle stop screw.
    The fuel system should be tested via the suite of tests in the Bentley manual
    as invalid rail pressure can be a contributor to idle and starting problems. A
    simple injector check is to pull the injectors, jumper the fuel relay to run
    the pump, and see if the injectors are leaking. You can also point the
    injectors into a towel, remove the coil wire, and crank the engine to see if
    all of the injectors appear to be spraying in a similar fashion. The best
    approach to possible injector problems is to have the injectors cleaned and
    flow tested. Since raw fuel can or will be released in these tests, have a
    fire extinguisher handy.
    The O2 sensor can be a contributor to idle problems. The O2 sensor is a
    scheduled maintenance item with a useful life of no more than 100k. If the
    sensor has that mileage or more (or is of unknown age), replace it.
    The AFM can be a contributor. If the vane doesn't move freely or the
    resistance track is worn the DME may be receiving invalid data from the
    AFM. And if someone has fiddled with the bypass air adjustment the DME may be
    unable to stabilize idle. The bypass air adjustment should only be adjusted
    per the procedure in the Bentley and with an exhaust gas analyzer. And even
    then everything else associated with engine management has to first be
    operating properly. If the AFM becomes a suspect, replacement with a good used
    unit is the best approach.
    Improperly adjusted or malfunctioning valves will affect idle and starting. As
    can compression issues from ring or cylinder wear. A valve adjustment is
    called for every 15k. A useful diagnostic is to run compression and leak down
    tests on the engine. And aged ignition wires, plugs, distributor cap, or
    rotor can cause problems. Insulation does break down with time and heat. And
    since the youngest E30 is going on 19 years old, if the ignition system is
    original or the plugs are old replacement is indicated.
    Although not usually a problem, a bad DME temp sensor is a possibility. That
    generally won't cause an unstable idle, but can cause hard cold or hard hot
    starts and/or a rough idle. As can problems with the timing reference sensors.
    When all other possibilities have been eliminated and idle or starting
    problems persist, replacement of the DME, or if applicable the ICM, is
    indicated.
    • bryant.cw
      • 209
      Cap and rotor are new. Plugs are new. ICV looks new. AFM looks newer, or at least in really good shape. Car has less than 130k. I have run 3 sets of injectors, 2 were rebuilt, and no change. (Other than 19lb injectors causing the car to run worse)
      Smoke test seems to be in order. I doubt I'll find a good place to do it, sigh.
      Great post, thanks.
      • bryant.cw
        • 209
        I put back my rebuilt injectors and removed 19# ones, running better. I ordered some bosch plug wires, the ones that are in there look original; I can see cosmoline on them. I tested for vacuum leaks with carb cleaner and found nothing, all the hoses and connections look very good to me. I will post back when I have installed the plug wires.
        • Sagaris
          • Sep 2009
          • 2243
          Most of my cars running issues when I bought it were due to 180k mile old plug wires. It hesitated badly and the idle was a bit chunkier than it should have been.
