Hey guys, I've been loving driving the E30 for the past few months. 87 325is budget car. Lately (within two months of beginning to drive it regularly) I'm having acceleration issues. I've replaced the intake boot, cleaned ICV, Maf, replaced visibly cracked vacuum hoses, checked with tbc for vac leaks at the gaskets. Head of this car was off ~2k miles ago, gasket etc all replaced. Exhaust is tight, cap/rotor and plug wires were replaced with head work.
The car drives well overall, has plenty of issues but nothing major. Unless I'm leaving a dead stop. If I put the throttle 1/3-1/2 way down the car accelerates fine. If I mash the pedal the car bogs down, stays at idle speed and on one occasion stalled. When it bogs down I have to coast until the car reaches about 1200rpm then I can accelerate. When hitting the kickdown switch at any speed above 0mph the car reacts as normal.
I pulled the plugs this afternoon and all were normal wear, no deposits or discoloration.
I know the oxy sensor needs to go (no idea on age and car runs rich) but I've driven M20s with bad 02s before and not had this symptom. My best guess is bad fuel filter. No idea on the age of it. This sound correct? And I have an unused filter made to fit an M60 car (94 540), could I put that in the place of the stock one long enough to run the car, or will I cause more damage.
Lastly, what are common symptoms of having a clogged/bad cat on the E30? If its not a fuel filter my only other guess is back pressure from a plugged cat.
Cliffs: car with man tune-up parts replaced bogs at full throttle from a stop. Clogged fuel filter?
