What are the usual symptoms of dirty fuel injectors?
injectors dirty? how to diagnose?
The most common symptom of dirty injectors is a rough idle. But since a rough idle can be caused by intake leaks, aged plugs/wires/distributor, aged O2 sensor, fuel pressure problem, valves out of adjustment, or a bad AFM, a rough idle doesn't necessarily mean injectors.
A smoke test of the intake will reveal any intake leaks and a check of rail pressure will tell if there's a problem there. Plugs, wires, and distributor should be replaced if they have significant age on them. A european can may not have an O2 sensor, but if it does and it has 160km on it the sensor needs to be replaced. Valves should be adjusted and it would be a good idea to run compression and leakdown tests to see if one or more cylinders are down on compression enough to cause misfires. With the other causes eliminated, the injectors move to the top of the list.
A DIY check is to pull the injectors & fuel rail, disconnect the coil, point the injectors into a towel, and crank the engine. Noticeable differences in the spray pattern or leaking from the injectors would indicate a need for cleaning and flow testing or replacement.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Running rough when cold could be intake leaks, bad ECT sensor, or injectors. Since the engine runs smooth when warm, I'd say that intake leaks or a bad ECT are more likely than the injectors.The car makes it possible, but the driver makes it happen.
