Need part #'s for intake plate and TB elbow
    Can't see thes in realOEM. The blank/vacum plate for "i"s and the alum elbow for the ICV into throttle body
    Leave now before I shed my human form and kill you
    The first part should be 1161708859. The throttle body elbow is not available as a separate part. It is only available as part of the throttle body. If you are missing that elbow, your best chance is to get a throttle body from a salvage yard. If you have the elbow and it is just loose, throughly clean the nipple and bore with acetone or lacquer thinner and JBWeld it back in place. Allow JBWeld to cure overnight before running the engine.
