Intermittent Hesitation
  • Jay87
    • 57
    Hey folks,
    Car is an '87 325is, stock so far as I know. Every once in a while, the car hesitates on acceleration. At one point, cruising down the freeway, I jammed the gas pedal and the engine nearly stalled before catching (this happened very fast). It was almost like I killed the ignition for a half a second.
    My first thought is fuel - the car has an inline fuel pump that was replaced last november by the previous owner, but that whines incredibly loudly.
    The second is spark, though I'm not sure why this would fail intermittently.
    I figure I will replace the fuel pump and filter first and see what happens. Where can I find a cheap fuel pump?
    Thanks,
    Jay
  • Sagaris
    • Sep 2009
    • 2243
    When I first bought my car, It hesitated like yours and I went through and replaced:
    Oxygen sensor
    Coolant temp sensor (to the ECU)
    Spark plugs
    Distributor cap + rotor
    Spark plug wires
    each item improved the hesitation slightly but the Distrbutor cap +rotor and the sparkplug wires were what completely cured it. They were original @ 187k. You also may have an intake leak but Im betting on ignition components.
    • 2.5-12
      • Jan 2010
      • 1814
      this same thing was happening on my 87iC, it turns out my 02 sensor was completely gone and the car still wasnt throwing a CEL For it,
      new sensor and no more hesitation and almost dieing on the highway
      if that doesnt fix it, do everything that Sagaris mentioned, its good preventative maintenance anyway on an older car and well worth the initial cost.
      1991 E30 M3 Brilliant/black - S54B32/5M
      1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
      2011 E82 1M VO/blk/6M
      1991 E31 850i red/grey/6M
      1997 F355 spider red/tan/6M
      • sohc12vm20
        • Jan 2010
        • 688
        Sounds like the 02 sensor needs to be replaced..
        • rabbitude
          • Jan 2010
          • 247
          It may be the O2 sensor, but I had the exact same problem which turned out to be a vacuum leak which was causing the O2 sensor make the car super lean and the car was starving for fuel
          070 by wonderwilley, on Flickr
          • Jay87
            • 57
            Thanks for the replies. I'll look into an O2 sensor, I don't believe its been replaced. The previous owner said that most of the ignition components were replaced, but I keep finding reasons to doubt his work...
            • Jay87
              • 57
              I know I might get flamed for this, but how about a universal O2 sensor? Waaay cheaper than an E30 specific one, unless I don't know where to look.
              • iwantspeed
                • 3164
                I had a similar issue
                I replaced quite a few things trying to diagnose it.
                cap
                rotor
                plugs
                I didnt replace the wires but I plan on doing that soon.
                air filter
                fuel filter
                oil change
                oil filter
                various vacuum components
                o2 sensor
                main relay
                ecu relay
                o2 sensor heater relay
                crank position switch
                main engine ground strap
                fuel pump
                coolant temp sensor(blue base goes to dme)
                mine was fixed by swapping out the ecu with a stock ecu with a stock chip.
                I assume there was a cold soder joint, a broken joint or something of that nature.
                the car still has an occasional long cranking to get it started.
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • iwantspeed
                  • 3164
                  also found this
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
