torque spec's on 89 325i headbolt's
  • KillaCam
    • 2103
    i have heard different things and my stupid manual doesn't tell me it only says for the m42 engine
    i am using torxx bolts
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
  • Sagaris
    • Sep 2009
    • 2243
    I know its a fraction of the torque required to strip the shit out of them :giggle:
    • KillaCam
      • 2103
      funny guy^^ lol
      • Sagaris
        • Sep 2009
        • 2243
        Just for the sake of upping my post count I will make a separate reply for the "Why so serious?" answer
        From the Bently pg 64 of the Engine section
        Cylinder head to cylinder block
        6 cyl engine (Torx head)
        Stage 1: 30 Nm (22 lb-ft)
        Stage 2: 90 degree torque angle
        Stage 3: 90 degree torque angle
        6 cyl engine (Hex head)
        Stage 1: 40 Nm (+5/-0), (30 lb-ft +4/-0)
        Stage 2 (after waiting 15 minutes) : 60 Nm (+5/-0), (44 lb-ft +4/-0)
        Stage 3 (with engine at OP. temperature): 20 degree (+5/-0) torque angle
        • KillaCam
          • 2103
          thanx man =]
            In case it isn't obvious by the fact that the bolts are angle torqued, head bolts are one-time use fasteners. Once you pull them, you throw them away.
            • The Dough
              • 45
              I just replace my hex head bolts for torx style ones. When I replaced the hex ones, they all smelled of burnt oil. The two at the back of the engine were covered in oil.... Wonder what thats about?
              Anyone shed any light on that for me?
