I was trying to replace the exhaust manifold gaskets/heat shields. While trying to remove the nuts from the studs, 9 of the 12 came off, 3 or 4 of which were nut and stud, the other 3 were stripped because I was the first person in 24 years to try and remove them and they were completely rusted. I was looking on pelican parts for which size I needed. The vehicle is an 86 325e 4dr. The only stud I saw was listed for a 325e coupe (they're probably the same). Also they have listed locking nuts, and copper nuts. What do I need?
Thanks
Thanks
Pelican Parts lists "Exhaust Flange Stud, 10 x 35mm, 3 Series, All, (1984-91), As Needed" which is the size that is given in the description for part #7 on that photo but also lists Exhaust Stud, Head to Manifold (8x40mm), E30 318i/iC, 325/e/es/i/is/iC/iX, As Needed.
