changed my timing belt, now its leaking coolant.
  • 2.5-12
    • Jan 2010
    • 1814
    I changed 4 timing belts in the last couple of weeks, I have just started to notice my iC is leaking coolant.
    I want to say that its coming from the water pump because I dont see a leak from anything.
    what could I have bumped or screwed up when doing the timing belt?
    can I change a waßerpump without screwing over my 15 day old timing belt job?
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
  • ak-
    • 12422
    Check your hoses/clamps again, and again, and again, and again, and again, and again, and again, and again, and again, and again. I swear.
    Clean up where you see the coolant, then have your buddy rev the motor and track down where it leaks. Repeat these steps.
    Took me a good while till I found out I had a rotten hose from a hidden hose under the thermostat housing.
    1991 325iS turbo
    • 2.5-12
      • Jan 2010
      • 1814
      I shall do that. I'm sure you're right though -- I un-did every hose clamp in the system to do the t-belt
      • Sagaris
        • Sep 2009
        • 2243
        I did my timing belt , didnt use RTV silicone sealant(many have success without using it, I didn't) It leaked from the mating surface between the water pump and the block. I had to tear it all apart and redo it using a new gasket on the water pump and some RTV . Certainly annoying, but not a huge deal in retrospect.
        • 2.5-12
          • Jan 2010
          • 1814
          i didnt change my pump though...?
          • TrackjunkiE30
            • Sep 2009
            • 151
            Originally posted by Sagaris
            I did my timing belt , didnt use RTV silicone sealant(many have success without using it, I didin't) It leaked from the mating surface between the water pump and the block. I had to tear it all apart and redo it using a new gasket on the water pump and some RTV . Certainly annoying, but not a huge deal in retrospect.
            +1... Happened to me too. I used RTV the second time and problem fixed.
            But did you remove it and reinstall? And yes, you can remove the WP without messing with the TB.
            John
            2013 NASA-SE TTE Champion
            Tracks driven: AMP, Barber, CMP, CMS (Lowe's), Daytona, NCCAR, Road Atlanta, Rockingham, RRR, Sebring, Texas World Speedway, VIR (Full, Grand, South, North, & Patriot), Watkins Glen.
            • Alpinweiße30
              • Jun 2010
              • 73
              No RTV for me and no leak. I have not put many miles on the car, just a few up the street and back.
              • 2.5-12
                • Jan 2010
                • 1814
                I didnt do anything to the water pump on thie timing belt change, yet, it now appears to leak. only when running.
                I may just sell this car. I am so over automatics anyway.
                • JTapper
                  • Sep 2009
                  • 847
                  I saw it listed on CL today. Bad move. Let's have and auto/manual swap party.
                  Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
                  • 2.5-12
                    • Jan 2010
                    • 1814
                    if I could get the damn nuts off the exhaust, I would be in process.
                    I love the car but I just can't stand automatics. the water pump is the least of my worries, thats only 3 or so hours to completely re-do.
                    having an auto trans makes that job a lot harder too. stupid a/t cooler lines.
                    what parts did you say you were missing for your swap? I have my ES manual parts car as well as all the parts i need to do mine.
                    • JTapper
                      • Sep 2009
                      • 847
                      I need everything but pedals and a g260. I have a few of each.
                      Meaning I need:
                      Driveshaft
                      Master
                      Slave
                      Lines
                      • 2.5-12
                        • Jan 2010
                        • 1814
                        I still have a drive shaft from the ES, the boot around the CSB is cracking but it certainly isnt failed yet and thats not expensive or hard to change
                        I have a master
                        I have a slave
                        I may have an extra hard line (NLA new), the soft lines are available still.
                        my vert' is looking so lonely out on the driveway :'(
                        • Alpinweiße30
                          • Jun 2010
                          • 73
                          You talking about the nuts that bolt the manifold to the block? Mine were so rusted as soon as i put a wrench on it a few crumbled. I am going to dremmel the nuts off and use vise grips to get the stud off once the manifold is off. I got everything to replace it all for like $10
                          • JTapper
                            • Sep 2009
                            • 847
                            Hard to believe you bought the proper studs for that price. Where did you get them?
                            Manifold hardware isn't cheap.
                            • MoparJ
                              • May 2007
                              • 258
                              Do This. I had a leak after changing the radiator, and it was because the clamp on the hose coming from the water pump wasn't tight enough. Those clamps down there are a serious bitch to tighten properly due to tight space.
                              Jason
