Changing tube of death?
    Once you pull the intake manifold once it gets much easier. The first time I did it, it was a bitch. Then I forgot to put the damn tube in first and had to pull the manifold again, much easier once you know how to go about it. I also used the zip tie method.
    Flickr
    @michael.colby on Instagram
    "All he needed was a wheel in his hand and four on the road"
      Bumping this oldish thread cause I am finishing this job now. I replaced the following:
      All coolant hoses
      Thermostat housing and thermo
      Coolant temp sensor, (the blue one)
      Intake gaskets
      Throttle body gasket
      Oil return tube seals (zip tie method works)
      Spark plugs
      VC gasket
      All vacuum hoses
      Definately the hardest part seems to be unbolting/bolting the 12 intake manifold fasteners. Aligning the mani was hard, but I was alone without help, 101 outside in the sun. I have the mani on but not completly bolted up yet. Still a bit to go.
      Any suggestions on making the rest of the job easier? I have the bitch tube in already.. LOL. It really wasn't much problem but getting the zip ties ON was a bitch.
      sigpic 1987 325is
