Hey folks. Due to corrosion and needing an increase in comfort/confidence level I replaced my hard fuel lines this weekend. Now the car will not start. Ran fine before and I'm sure it is because it is not getting fuel
The vent line that runs from the top of the tank to the charcoal canister I feel pretty sure I reconnected correctly. My question is about he path of the sending and receiving lines, as I may have them crossed up at the engine end.
Here is how they are currently routed. Starting at the tank end.
Sending line runs into filter/out of filter, then into hard line and then up around the engine and into the rail at the rear end of the rail (closest to windshield).
Recieving line runs straight into tank and then into hard line and up into the pressure regulator.
Should the sending line send fuel into the regulator first and then exit at the rear of the rail and into the receiving line?
Would this cross up make the car not start?
Thanks in advance. Car is an 88 325is
