I know it is not an e30, but it does have an ETA motor so I was hoping you guys could provide me with some insight or some personal experience.
I just purchased a 1986 Euro 525e and have been struggling to get it to pass emissions. I will start off with the scores, and then explain what I have done so far.
25/25 Test
Reading Allowed
HC 12 157
CO % 0.01 1.00
NOx 2277 1121
50/15 Test
Reading Allowed
HC 12 162
CO % 0.01 0.91
NOx 2421 1227
I have read every thread in here that I could find with various suggestions on what the issues could be, as well as little tips to help it pass. I am down to 6 days to get it to pass before I can no longer legally drive the car, as I was out of town for a week and a half after I purchased it. The car runs well, and runs cool as far as the water temp goes, however the high NOx is pointing towards it running lean.
I found and fixed a vacuum leak, tested the O2 sensor, and while it appears to be working (Varying voltage) it may be malfunctioning. I am going to replace the 02 sensor ASAP, as it is a single wire so relatively cheap. Per a bad recommendation, I did replace the catalytic converter against my gut feeling, and it made 0 difference, so that is not the issue either. Plug wires appear to be in good shape, as well as the plugs. I do not believe the car has an EGR valve.
Any further tips or suggestions would be great, or if you need more information please let me know. I have done tests after fixing the vacuum leak, as well as the new cat, and neither of those were the issue, nor did they make a significant difference. Thanks in advance!
25/25 Test
Reading Allowed
HC 12 157
CO % 0.01 1.00
NOx 2277 1121
50/15 Test
Reading Allowed
HC 12 162
CO % 0.01 0.91
NOx 2421 1227
