Today when I pulled up to a stop light and put in the clutch my engine began idleing very oddly. The idle was going up and down lower than normal. At the next light however it didn't do this. I did notice however, that when I stopped the engine idled at a hundred or so rpm higher than usual then dropped to normal. I'm not sure what is causing this. I know when I turn on the a/c it idles a fair ammount higher and is much louder but still runs. The enigine is very strong and only has around 80k on it. The clutch isn't to old but I wonder if that is the problem. Any help appreciated.
wierd idle
