HELP...turning crank/camshaft for valve adj.
  • danalyse
    • Apr 2009
    • 153
    I am in the process of trying to adjust my valves. How the heck do you turn the camshaft in an automatic.
  • IronmanE30
    • Sep 2009
    • 2121
    Have you tried putting the trans in neutral and using the crank nut on the bottom front of the motor?
    Cheers,
    Jim
    • danalyse
      • Apr 2009
      • 153
      Camshaft
      Too hard to get to crank. Took cap off and am able to turn via a socket on the camshaft pulley bolt. Do you happen to know the valve clearances.
      • whodwho
        • Jun 2008
        • 1547
        This is a REALLY bad idea, that will stress the T belt!! Especially if the plugs are still in...
        Don't know what year you have but look into using the diagnostic connector to bump the starter.
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • danalyse
          • Apr 2009
          • 153
          Turnining the camshaft
          I certainly took out the plugs and it all turned over fairly easily. Will try something diifferent next time.
            Method 1:
            Jack up the front of the car and use a wrench on the crank bolt from underneath. Having a helper makes this pretty easy.
            Method 2:
            Rig a push button switch to pins that will fit the diag connector and bump the starter.
