oil in spark plug and 5 cylinders
  • 90Degrees
    • Jun 2010
    • 62
    hi there, a friend of mine is having some issues with his m20. Theres seems to be oil that gets trough to one of his spark plugs and he's running on 5 cylinders now. Bubbly, like harley sound. Before it would start up on 5 then after a few seconds everything would be ok. But now it stays on 5. Do you guys have any ideas on what could be the cause ?
    1989 325i.
  • whodwho
    • Jun 2008
    • 1547
    Start with a compression/leakdown test and see how the basic engine is, if it is low/bad then there is some major work needed.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • 90Degrees
      • Jun 2010
      • 62
      nvm, i went to check and two spark plugs were not screwed correctly.
      1989 325i.
      • sonnyqm3
        • Sep 2009
        • 1144
        check the valve cover gasket. might be a good idea to change the gasket..
        • 90Degrees
          • Jun 2010
          • 62
          yup, im adjusting his valves this afternoon and were changing it too.
          1989 325i.
