Car is a 85 325e with a 87 "i" motor. PO had car stored for some time non-running. The engine has a fresh head with all new parts and a 284 cam. The car has ran with this setup so its not a project that just got done and it wont start. It has been together and driven about 3-5k miles since the head rebuild.
So the engine is getting spark. Cranks fine but doesnt fire. I took the spark plugs out and cleaned them, they had a little excess fuel on them so I know this isnt a "no fuel" problem. Not sure if maybe the injectors are dumping to much fuel or not. It didnt seem like it had that much fuel on the plugs so they wouldnt fire...
I also changed the AFM because the one on the car had the settings adjusted to help run with the cam. I installed a stock AFM and still no life.
Nothing looks unplugged. I checked all the vac lines and everything.
Any suggestions?
TIA
Any suggestions?
TIA
