ok so I bought a 89 325i with a bad head gasket.
The issue is isolated from the engine oil into the cooling system. Runs no smoke / steam.
While the head is off my plan is to replace the following
HG and new bolts
timing belt and tensioner
cam seal
crank seal
intake and exhaust gaskets
all vacuum lines
thermostat
water pump if needed
all coolant lines
Have I missed anything??
HG and new bolts
cam seal
crank seal
all vacuum lines
thermostat
all coolant lines
