M20B27 swap C101 help!!
    Where the hell do i wire in the C101 on my eta engine??
    I know what all the wires are, but im wondering if i have to put power to certain wires? if so, which ones?
    A picture i saw had descriptions it was:
    pin 1 = D+ = alternator charge indictor
    pin 2 = sta = oil level - static
    pin 4 = ft = coolant temp guage
    pin 5 = ol = oil pressure
    pin 6 = 15s = voltage with ignition turned on (fuse protected)
    pin 7 = 15u = [same as above, but non fuse protected]
    pin 10 = dyn = oil level - dynamic
    pin 11 = SI = service indicator reset
    pin 13 = EP = electric fuel pump
    pin 16 = A = air bag
    pin 18 = 50 = voltage while starting.
    P/s this car is stripped of everything.
