i thought my fuel pump was out. so i bought another one.it dose not come on. what i have checked so far, fuse 15amp #11 (or 10) relay... pump runs when i jump #87 , injectors (new ford 19lb) they work when i turn key to start. the car turns over, but dose not start. the fusible link in truck rings out like it works fine.it has 13 button computer, i replaced the relay for that (black box above abs), ive disconnected the battery for 24 hours. my questions i need help with, if the sender in the tank dosnt work dose it stop the pump from working? and will the sensors on the bell housing and afm shut it off if they are broke? or is it my dme? or did i not check something that i should have?
