do i need this or this
  • pharow
    • Jul 2010
    • 1021
    i was messing with my car today. i was looking at the front in the grill, and i saw a black electric fan. now the thing is i want to get rid of the crank-driven fan. can some one tell me wht the ele. fan is for, and if tht fan is working do i need the crank fan? THANX in advance!
    my car is an '88 325is auto.
    '02 Outback wagon
    '87 325is 5sp
    '93 Kawasaki ZR1100
  • unkown
    • Mar 2008
    • 83
    you need both, to cool motor
    • Aptyp
      • 6584
      i've had my fan clutch off forever now.
        The fan in front of the radiator is known as the aux fan. Its purpose is to provide additional airflow when A/C is in use and the car is stopped or moving slowly. The main airflow for engine cooling is provided by the engine driven fan. The engine driven fan can be replaced by an electric fan, but the cost of doing so correctly exceeds the cost of replacing the engine driven fan with all new parts.
        On a race car, replacing the engine driven fan makes sense. It doesn't on a street car, especially if the car has a working A/C system.
        • pharow
          • Jul 2010
          • 1021
          well my a/c did not wrk...so i removed the compressor and a few of the lines to it.
          ok, so i really dnt know wht all is in front of the car. wht is the lil small cooler thing up front on the bottom? it is real small and kinda thin.
          '02 Outback wagon
          '87 325is 5sp
          '93 Kawasaki ZR1100
          • chadthestampede
            • Jul 2008
            • 3600
            ^oil cooler
            Originally posted by LJ851
            Feedback
            • pharow
              • Jul 2010
              • 1021
              ok oil cooler. tht i know has to stay!
              '02 Outback wagon
              '87 325is 5sp
              '93 Kawasaki ZR1100
              • whodwho
                • Jun 2008
                • 1547
                Put a lower temp fan switch and you can run just on the aux fan, works fine in 100*+ california heat.
                My M20 Frankenbuild(s)
                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                • pharow
                  • Jul 2010
                  • 1021
                  where can i get a aux fan temp switch?
                  '02 Outback wagon
                  '87 325is 5sp
                  '93 Kawasaki ZR1100
                  • pharow
                    • Jul 2010
                    • 1021
                    whodwho do u mean the temp sw tht bmp sells? i need a new 1 any way. i just checked the fan by jumpering the wires, but whn it is connected to the switch, it does not come on. so i have to place an order for it...darn.
                    '02 Outback wagon
                    '87 325is 5sp
                    '93 Kawasaki ZR1100
                    • whodwho
                      • Jun 2008
                      • 1547
                      Sorry missed your other post, I am using a 75c thermostat, 80/88 fan switch. I am also using a Mishimoto radiator and it runs a bit on the cool side so I am going to swap out the 75c thermostat and try an 80* one.
                      Do you have a 3 pin one or 2 pin?
                      Here is one from Pelican for the 3 pin one I am using
                      BMP is probably selling the same one, Part # for fan switch is 61-31-8-361-787
                      http://www.pelicanparts.com/cgi-bin/...i%20M%34%32%20
                      • pharow
                        • Jul 2010
                        • 1021
                        it is a 3 pin plug. thanx, it is cheaper then the bmp one. i will be putting it on order soon. then when i get it and make sure it wrks, i'm taking off the other fan and a/c stuff. thanx again!
                        '02 Outback wagon
                        '87 325is 5sp
                        '93 Kawasaki ZR1100
                        • pharow
                          • Jul 2010
                          • 1021
                          i love ur car's set-up! i love super chargers. way more then turbos...i dont knw y...
                          '02 Outback wagon
                          '87 325is 5sp
                          '93 Kawasaki ZR1100
                          • whodwho
                            • Jun 2008
                            • 1547
                            Thank you, I have always had turbos in the past and this is the first SC. This SC has worked out well and I like the power delivery but is boost limited.
                            • pharow
                              • Jul 2010
                              • 1021
                              i dnt thnk i would care about tht if it was my car. pleez keep up the post. i need ideas. wht is the pwr output of ur car.
                              '02 Outback wagon
                              '87 325is 5sp
                              '93 Kawasaki ZR1100
