Seems like after I finally got my m20 2.7 stroker built and running im leaking oil from the exhaust manifold stud on the very front of the motor. the very first stud is leaking oil. Is this possible? Maybe run a different oil weight? Im running 10w-30 since I figured its completely rebuilt...Anyone had this problem?
Oil Leaking from Exhaust Manifold Studs?
changing oil will not stop a leak, you should try to pin point it. All you have to do is find the highest point of the leak to know what it is. Make sure when your checking you have lots of light, and as levie said, no oil cant come out of the stud.
If worst comes to worst, use a little dye before your next oil change that really helps to find leaks but I dont want to go recommend putting anything in your motor other than oil, i just know from work we use it alot and it works great.Comment
