m50 clutch in 1985 325e?
  • So Live
    • 2512
    Hey does anybody know if i can use a e36 325i clutch disc in a 1985 325e? I know the e36 disc is 9" O.D. and im pretty sure they share the same input shaft. Would i need to run the e36 pressure plate too?
    My eta needs a clutch pretty bad and i happen to have a stock 325 clutch with a lot of life left. This is my beater car so reusing parts that still work is what its all about.
    Any insight would be much appreciated.
    Thanks!!!!
    -Chris
  • 2.5-12
    • Jan 2010
    • 1814
    id say no, but only because I know for the most part when you run an E36 clutch component, you need to run everything incl. the flywheel, starter, pp, etc.
    Eta clutches arent much new also.
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
