hey im trying to put a mild camshaft on my m20 in my 88 325. im looking to either get a stock cam with bigger profile then mine or get a cheap light cam. im going cheap because eventually i will be doing a s52 swap. but i use my m20 as a daily motor so would like little pep out of it. i was wondering if the e30 m3 cam or the 325e camshafts are bigger and would fit my 325? on honda's the economy cams are bigger for the torque so people can use those on the dx versions and get little more power. was wondering if thats same with e30s?
m20 camshaft advice??
how do i find out if my motors a seta motor? im new to the bmw stuff. all i know is its an 88 bmw 325 coupe automatic. i converted to 325e 5speed conversion. stock auto rear end. has 325is throttle body. 89 5 series 5 speed ecu. either then that its stock just lowered with wheels. stock cat with dual straight pipe cat back.
Originally posted by SpecM View Postits a seta
get a stock 2.5 camshaft and springs. Its a nice upgrade for a seta.
and don't even try to use a m3 cam haha (its a 16v 4 banger)
S14 is a pure sex 4 banger."Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
"People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
What do you mean by bigger cam? Are you talking about bigger lift, longer duration?
there are a lot of aspects to a cam choice and it is not a best idea to just start swapping cams without knowing exactly what you are looking for. most cam swaps move your powerband. they do not add huge amounts of power but they are effective for moving the powerband to more desirable higher rpm range. this is great on the track but does not make a lot of difference on the street where you are not trying to rev the engine to 7000 rpms.
im using a 5speed ecu out of an 89 5 series. i did a 5 speed conversion on my 88 325. with this ecu i hit 7000 rpm now. im looking to get different duration. i would like my power band little bit higher then at 3000 to 3500. i would like it to be around 4000 and keep gaining. i will of course get little bit bigger 19lb injectors and brand new walbro fuel pump or customize a e34 in tank fuel pump onto my in tank fuel pump system so i can get more fuel going. so i should get some good amount of power gain with all this.
