m20 ford 3" mass air flow sensor mod?
  • 88e30dippin
    • Jul 2010
    • 39
    i found that a ford 3" mass air flow sensor can be used. has anyone tried it? if you have which car, year, make models, can i use and how the wiring was done?
  • SpecM
    • Oct 2005
    • 4531
    well if you're so sure it can work, why don't you tell us?
    1989 cirrisblau-metallic 325i
    • blueapplesoda
      • Dec 2005
      • 1904
      Yes we would love to know.
      • 88e30dippin
        • Jul 2010
        • 39
        well theres a guy parting out his 318is and he has the ford 3" mass air flow sensor wired in. works same as the miller maf sensor kit for the e30. the ford 3" maf sensor is diy that idk how to wire up. idk if you can just take one and wire it up to the maf sensor clip or if theres more to it.
        • MonkeyMadness
          • 3251
          There's more to it; the wiring is more just for the 12v need by the MAF. the afm only uses 6v, I have a war chip/maf mod.. You can learn alot just by going to there site and
          reading the manuals... in the pdf. files, and the forum it free to read. No need to sign up.
          The wire mod is easy. basic just cut the 6v and tap in to a 12v lead in to the ECU
          If I remeber right I think it's cut pin 12 and tip in to pin 37?
          But the problem is that the ECU is looking for info from the AFM and can't tell you running a maf it'll start and idle but that's it.. You'll need to find a chip that can correct the problem.. If the guy's running this he must? have the chip to offer as well..
          Did he run it or just pick it up from a yard?
          But it's worth it fucking awsome Mod.. Totally brought my M20b25 to life...
          hope this helps
          • 88e30dippin
            • Jul 2010
            • 39
            MonkeyMadness man you helped out alot. i will look that up. the guy had it done at a shop. he doesn't even know how to wire it up at all. today before i read your reply. i tried wiring up a 95 volvo turbo maf sensor. all i did wise wire it up to the old wires exactly the same way and it did what you said which was it would idle but thats it. how much is the chip? and where can i get it?
            • 88e30dippin
              • Jul 2010
              • 39
              oh and the guy who is parting out his e30 has a 90 318is not 325. so would that chip out of his 318 work on my 325 ecu?
              • Jean
                • 18228
                srs?
                • MonkeyMadness
                  • 3251
                  No his 318 chip will not work with your 325.. sorry
                  I'm not sure but i think you can buy the millerperformance chip for the maf by it self
                  Call or email Brody, tell him whats up and he'll totally help you
                  the guy's awsome..
                  Good luck and I'm glad I could help..
                  http://www.millerperformancecars.com/index.php
                  Brody Saari
                  Miller Performance Ltd
                  604 755 7692
                  • 88e30dippin
                    • Jul 2010
                    • 39
                    thanks a lot
