check engine light help
  • call me jack
    • Jul 2010
    • 425
    So i bought a car a few months ago, not running, because it was in a accident.. it had front end damage, and needed a new bumper, and radiator. Well i finally got the car all put back together, and i have a check engine light on... i don't have the tool to clear it, or read it, but all of my connections are good, and the car has oil... so with it said that every thing checks out ok, do you think it's ok to drive? i see videos of people driving their e30s with cels semi frequently...
    the only thing that makes sense to me is that a code that was thrown, during the accident is simply still present in the computer.
    thanks for the input. on a side note, i will be buying a code read device soon...
    edit: car is an '87 325e
  • ///digitalme
    • Dec 2009
    • 2088
    check the codes..."stomp test"...
    • call me jack
      • Jul 2010
      • 425
      what is the stomp test? i've read about it in passing, but i dont' really understand it in any detail...
      • ///digitalme
        • Dec 2009
        • 2088
        1. turn the key switch
        2. pump the gas pedal 5 times(the check light should stop flashing and will give you the codes) if it blinks one time=1 then it stops and blinks again it should give you the next number in flashes...so three flashes=3 and so on...
        heres a video to help you out
        codes are 4 numbers only...
        heres a site to help you on the codes...
        Find information, resources and relevant links for e30world.com. This domain may be for sale.
        hope it helps
        • StereoInstaller1
          GAS
          • 22679
          How about posting what year/model you have?
          Closing SOON!
          Thanks for 10 years of fun!
          • call me jack
            • Jul 2010
            • 425
            hey now thats a clever idea.
            it's an '87 325e
            • call me jack
              • Jul 2010
              • 425
              bump. since my car is an 87 325e, it cant' do the stomp test. More input would be appreciate
              • Dermeister3
                • 1184
                is it definitely the CEL?
                alot of people confuse that with the blinking "check" light that comes on when your overhead check panel has a light on. like for brake lights, until you hit the brake pedal.
                • StereoInstaller1
                  GAS
                  • 22679
                  If it is the CEL, try turning the key on (don't start) and counting flashes.
                  Closing SOON!
                  • StereoInstaller1
                    GAS
                    • 22679
                    oh yeah:http://www.unofficialbmw.com/repair_faqs/motronic.html
                    Closing SOON!
                    • call me jack
                      • Jul 2010
                      • 425
                      wait. i haven't hooked up my wiper cleaner tank, yet. are you say the "check" light (and it is in fact a check light) is only on because i have no wiper fluid? that is awesome and retarded all at the same time.
                      • StereoInstaller1
                        GAS
                        • 22679
                        Yeah, that isn't the CEL.
                        That is the indicator for the "Check" panel, AKA the DIC, Drivers Information Center.
                        Push the button to shut off the CHECK light.
                        It should also come on every time you start your car, and go off when you hit the brakes for the first time.
                        Closing SOON!
                        • call me jack
                          • Jul 2010
                          • 425
                          wow problem fixed. sorry for the really n00b question. it's my first e30, and i wasn't really anticipating a additional check system... so i guess i could say the car is good to drive.... awesome!
