Cranks but no start
  • spaceshuttle
    • 169
    Cranks but no start
    I tried searching couldn't really find anything. I have an 89 325i m20. I parked in my drive and when I went to start it up again it just cranks won't turn over. It's getting spark I think it might be a fuel thing I can smell gas when I am cranking it. What do you guys think?
  • Adrian_Visser
    • Jun 2006
    • 2823
    what do you mean it won't turn over? Is the starter turning over the engine or not?
    '89 Alpine S52 with goodies
    • spaceshuttle
      • 169
      It just cranks but doesn't fire up. I don't think it's the starter.
      • selturk
        • Dec 2008
        • 1197
        check your relays first.. fuel pump relay and the main relay.
        • spaceshuttle
          • 169
          Switched relays nothing changed
            The first check would be to see if you have spark when cranking the engine. No spark will be a bad main relay, bad CPS, no START signal to the DME, no unswitched power to the DME, a bad DME, no power to the coil, bad coil, bad ignition wires/distributor/rotor, or broken timing belt.
            If you have spark, the cause could be incorrect fuel pressure or a problem with the C191 connector under the intake manifold.
            • spaceshuttle
              • 169
              okay Its not sparking switched the main relay and CPS. It's getting fuel and the c191 is connected. How do I check the DME?
              • spaceshuttle
                • 169
                I checked to see if it was the ignition wires and swithed one and it was sparking while it was cranking then I tried it again and it had no spark.
                • StereoInstaller1
                  GAS
                  • 22679
                  You cannot use any other relay to replace the "main" relay: it is unique on the car.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • spaceshuttle
                    • 169
                    How do I check if its broke?
                    • Eecen
                      • Jun 2010
                      • 1235
                      You can make a jumper from the "30" terminal to both "87" terminals and test.
                      The car should run, but will not shut off until you remove the jumpers.
                      • spaceshuttle
                        • 169
                        How do I go about doing this I am not even really sure where to start?
                        • StereoInstaller1
                          GAS
                          • 22679
                          Get 1 foot of 18 ga wire and 3) 1/4" male spade terminals.
                          Make a chain of the 3 terminals...1 to the other to the other, so you have a chain of 3 terminals.
                          Remove the main relay and connect the 3 bigger wires (look under it to tell which is the bog ones) you MUST connect all 3.
                          Start your car, see what happens.
                          Closing SOON!
                          • spaceshuttle
                            • 169
                            So I figured out that only 2 cylinders have spark and all the rest don't should I still check the main relay?
                            • StereoInstaller1
                              GAS
                              • 22679
                              Got fuel?
                              Closing SOON!
