Hi, I'm kinda new to this forum and I just bought an alpine white e30 last sat. It drove fine when I picked it up. Then after 3 days, it just started to run like crap. Then it died, now it wont run. (1989 325i - M20 engine - M/T)
Heres what I know:
Any ideas? Thanks.
Heres what I know:
- Spark is ok on all cylinders ive tested them already, but it seems that there is no fuel going in the cylinders. (I dont smell gas when I pull the plugs out)
- I checked the main fuel relay and i can hear the pump running.
- I also removed the line going into the fuel rail and manually ran the pump and fuel seems to flow from the line.
- I also checked the electrical wiring from the injectors and there's a signal of approx 5v from the connector.
- I checked the injectors using the manual and the resistance reading is Ok.
Any ideas? Thanks.
