Check engine light, no code?
  • brody
    • Jul 2009
    • 334
    If your TPS is intermittent, you will not have full power all the time when you step on it. There are always people saying they didn't like X brand tuners chip because it didn't really feel that much different on WOT. 99% of the time it is because they were not getting into the WOT maps due to TPS problems.
    What you describe sounds like it is intermittently connecting the WOT output and you are feeling bursts of even more power. You can use a multimeter to determine if you have actual continuity. The WOT signal wire is the Brown Black wire on the 3 pin TPS.
    as for the files, just open the WAR Chip in "my computer" like a USB thumb drive and copy the files to the desktop or where ever. Send those to me.
    • Reeves
      • 54
      Yeah I've tested the TPS before and it checked out fine, and it normally works fine, but it seems when it gets hot it well act up a bit. I'm just going to buy a new one and rule it out.
      I'll get those files when I get a chance.. Thanks brody.
