Over the past few weeks, I've noticed a high-pitched whine from the engine when it was cold and off idle (like 1500-3000rpm). I thought it was a loose belt or drive bearing, as this is exactly what it sounds like. The noise is all but inaudable at idle, or when the motor warms up.
To double check, I removed both (no ac) belts and cranked the enigne. Noise still there. Replaced belts, and removed valve cover and plugged PCV hose. Noise is much louder and sounds like its comming from the head. With the cover off I can hear it at idle, but the noise still goes away once the temp gets up.
Could a worn rocker shaft cause this? All valve clearances and in spec and seem to stay that way between checks. The noise sounds 100% like a loose belt or worn drive bearing, but is not. (Its not the timing pulley either, I'm quite sure)
For what it's worth, it seemed to start after I switched to Mobil One 15w50. Any help/ideas welcome... please...
