Ok so I wanted to change ignition wires I found them in my closet plus original wires where getting old. But I put them in wrong firing order then the motor started back firing. Once I put them in correct order the car didn't want to start and I lost spark. What should I look at other than the ecu,ignition coil? Please help somebody
No spark
Tags: None
Now they are in correct order I'm not getting any spark I'm going to check the crank sensor, starting circuit,ignition rotor, distributor car make sure there is a clean connection. Now someone told me to look at the starter solenoid as well so I guess I'll put that on a check list.Comment
Simple logic says the last thing you touched is 99% certain to be the cause of your problem.
'89 Alpine S52 with goodiesComment
Simple logic? I put original wires on then put them in correct order in still no spark that's why I ask. If you can't help me then I'll ask someone on e30 tech not trying to be a asswhole but I'm kinda losing it with this car guys lmao. Thank anywayComment
