I just bought a 1990 325i with 238km not miles km's, 5 spd bone stock.
I got a really good deal cause the guy didnt want to sink any more money into this car. Water pump went and he slightly overheated it when the water pump pully killed the belt. The pully was rubbing on the part the crank sensor reads. He got the car towed back home to the shop where they told him it needed a t-belt and water pump and possibly a new motor cause it does not run now. I bought the needed water pump and t-belt before I even looked at the car due to I have the exact same car that needs those things changed over the winter. I pulled the plugs and did a compression test and it reads 170 across all 6 cyl. No big jumps in numbers just + or - 3. When pulling the plugs they looked bad like they have never been changed. I tossed new plugs in and it made the car run but very crappy. It has a very lumpy idle and when flooring it the car will not go above 2500 rpm. I pulled the valve cover and everything looks like it should. just replaced the cap, rotor and plugs with new units and it helped it out a bit more but still runs like crap. I tested the coil and it fires about a 3" spark. Can smell and see that the car is running very rich (lots of black smoke coming out of exhaust). I have not replaced the t-belt or the water pump or pully so the belt running the alt is not connected and shouldnt be the reason for the car running so poorly. I dont know what to look at next or what to replace next. I dont want to throw a ton of cash at this car right now due to a trip to vegas that is coming up in a months time and my civic has not sold. I am how ever willing to rob parts off my summer driven 325i that I have parked early for the winter as long as they dont require a ton of work to get off as its hard to work on the car where it is currently parked. Any help would be sweet and a great help as I want to get rid of my civic as I hate driving it. Thanks in advance.
OK bought car that didnt run or start was over heated due to water pump failure
current plugs very worn along with cap and rotor very worn.
replaced plugs, wires, cap and rotor car runs but does not idle nice or rev over 2500
did compression test reads 170 +/- 3psi across all 6 cyl
no oil in coolant and no coolant in oil
have not replaced t-belt, water pump and pully and alt belt.
