Hey guys,
Trying to diagnose a problem where my starter will not engage or turn over. Car is an '87 is coupe with a three-terminal solenoid.
I have battery voltage at Terminal 30 (from junction block). I will check to see if I get 12v from the small wire (terminal 50) as soon as I can get a second pair of hands. The braided wiring strap from the solenoid terminal opposite the line from the junction block is in place, though it looks old.
What I do not know how to check is whether or not the starter is properly grounded. I don't see an obvious grounding terminal anywhere. How can I check to see if the starter and solenoid are properly grounded?
