What would be the symptoms of a bad ICV? What does it do, anyway? It's $120 for a new one, and I'm skeptical that the DIY cleaning-out routine would last long. Failed smog test is my reason for asking.
idle control valve - what does it do?
from my experience with it, usually a bad icv causes your idle to bounce around 1000-2000 rpms or so.
FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
Originally posted by scabzzzzI stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
2002 325i - DD
2005 Suzuki SV650 - Toy
idle control valve...... controls the idle.......... It opens a air path at idle due to the fact the throttle butterfly is shut. This only allows an idle amount of air flow. If its screwed depending on which way it can cause the car to rev or it can be hard to start. Take the pipes of it and turn your ignition on you should hear it buzz and have a look through it
A bad idle control valve could be a contributor, but by itself it isn't going to be the cause of a failure to pass smog testing. Without knowing what part of the test the car failed I'd suggest that you:
1) Have the intake smoke tested and repair intake leaks as indicated.
2) Replace the O2 sensor if it has 100k or more on it.
3) Run the fuel system tests in the Bentley
4) Replace the ignition wires, cap, and rotor, and plugs
5) Adjust the valvesThe car makes it possible, but the driver makes it happen.
Thanks to all for the information.
Originally posted by jlevie View PostA bad idle control valve could be a contributor, but by itself it isn't going to be the cause of a failure to pass smog testing. Without knowing what part of the test the car failed I'd suggest that you:
