interchangeable parts Eta to I
  • Slick92GS-R
    • Apr 2005
    • 662
    i'm asking ...
    1. Power steering pump
    2. alternator
    3. a/c compressor
    4. clutch cover/pressure plate
    5. clutch disc
    6. Intake tubing/air flow meter (plug & play)
    7. throttle cable
    8. starter
    9. distributor/cap
    10. water pump
    -- do these jus swap over from one motor to the other ...
    --Hayden--
    '87 325 coupe- Trak Rat
    '93 318is- 4cyl's of fury
    '92 Integra GS-R--yeah, its fast..
    www.G2IC.com
  • rs4pro3
    • 5808
    1. Power steering pump-Yes
    2. alternator-Yes
    3. a/c compressor-Yes
    4. clutch cover/pressure plate-depends on what year to year
    5. clutch disc-also depends on year to year
    6. Intake tubing/air flow meter (plug & play)-AFM no, intake tube Yes depending on what ICV system and throttle body you're ussing
    7. throttle cable-Yes
    8. starter-Yes
    9. distributor/cap-Yes
    10. water pump-Yes but depends on what year radiator and cooling system your ussing.
    85 325e 2.7 ITB'd stroker
    • Slick92GS-R
      • Apr 2005
      • 662
      thats a great start ...
      --Hayden--
      www.G2IC.com
