Been talking about this in my build thread > Here <
So my hesitation theory went right out, the fuel filter was fine and even after I put another brand new one in, the sputtering hadn't stopped.
So I checked the plugs and they were bad, dark bad. They were brand new too after I did the head
I swapped in better looking plugs, fixed most of the "sputter" which we now know is a miss
I checked compression, 150 across the board
I checked the ignition coil, it's fine
I swapped the o2 sensor to a known good one, still missing but this + the better plugs has me running with MUCH less misses
A) Miss-Firing
B) Rich Mixture
So what could cause me to have a rich mixture besides the o2 sensor? Bad ECU? Also as a note I have had my idle running a bit high ~900rpm could this be why its running so rich? Normal is ~750rpm right, I'll fix that.
A) Miss-Firing
B) Rich Mixture
