only heat while on the gas??
  • m30power
    • Jul 2008
    • 74
    Just replaced my thermostat and radiator. It seems to have fixed my overheating problem! I am gonna replace my fan clutch this weekend.
    This started last winter. I only have heat while the car is moving, or if I am hitting the gas. The car still blows air, its jut not even warm when not on the gas.
    Any ideas?
  • E30Gus
    • Jun 2008
    • 781
    Clogged heat exchanger?
    • Killacortes
      • 1937
      i have the exact opposite problem. when im not on the gas it blows hot air like a bitch. but when im driving on the highway or faster than 40mph it blows cold air even though i have the heat turned up all the way!!!
      r3v does not fuck around. First you get banned, then they shoot you
      • FredK
        • 14763
        ^ reversed heater core intake and outlet hoses.
        • m30power
          • Jul 2008
          • 74
          I dunno how they could be switched the heat worked perfectly last winter. I didnt take any hoses off completely...Maybe ive got low coolant...I just bled it for the first time last night after the radiator went in.
          • StereoInstaller1
            GAS
            • 22679
            Yours is bubbles, the other is reversed hoses.
            Go bleed until you are sick of bleeding, then do it more.
            Closing SOON!
            Thanks for 10 years of fun!
              Yep, air in the cooling system. Try:
              1) Using ramps or a jack get the front of the car 1' or more higher than
              the rear. That will make the radiator and bleed screw the highest point
              on the engine and facilitate removal of air.
              2) With the bleed screw open, add coolant until no more air comes out of
              the bleed.
              3) Leave the filler cap off, or at least loose, and set the heat for max
              temp and fan speed. Leaving the cap loose will prevent air that's still
              in the system from causing a "coolant fountain" once the engine heats
              up. Start the engine and allow it to warm up to operating temp. As it
              warms up occasionally crack the bleed screw to release any air and top
              up the coolant as necessary.
              4) Once the engine is at temp bring it up to 2000-2500 for a few seconds
              several times. Then crack the bleed until no more air is released. At
              this point the heater should be throwing lots of hot air, which
              indicates that the heater core is filled with coolant. You may have to
              repeat this a few times to get all the air out.
              5) Drive the car a bit, allow it to cool back down, and recheck the
              bleed for air. Over the next few days you may get very small amounts (a
              few bubbles) of air out of the bleed screw.
              • m30power
                • Jul 2008
                • 74
                jlevie I used that exact thing last night to bleed it with the exception that i only did it one time. Had to spend time with the GF afer being on vaca for a week haha!
                will be doing this over and over again tomorrow!
                • StereoInstaller1
                  GAS
                  • 22679
                  and the next day, too
                  Closing SOON!
                  • txtorquemade
                    • 1758
                    Ok....so why is it so hard to bleed these systems??
                    Damn. Now mine is doing this.
                    sigpic 1987 325is
