Purpose of secondary battery wire (fusible link)
  • Flash
    • 691
    Just a general question about the 325e/i big battery cable's secondary wire with the inline fusible link and what its circuit controls.
    Thanks!
  • ChaseN
    • 709
    A quick look at my ETM shows it powering the main relay, fuel pump relay, DME, and diagnostic connector.
    HTH
    1991 318iS
    1992 911
    2006 330i 6-Spd ZSP people hauler
    Gone:
    1989 M3 S50B32, 6-Spd
    1990 325ix 5-Spd
      That is what that does. It's purpose is to provide full battery power to the engine management system when cranking the car. The starter load can result in a voltage drop across the primary cable and the separate wire for the engine management system avoids that drop.
      • ChaseN
        • 709
        I knew it was there to power those components specifically, but didn't know it was because of that specific reason. Awesome info!
        1991 318iS
        1992 911
        Gone:
        1990 325ix 5-Spd
        • engrlks
          • Apr 2011
          • 16
          I think I may have shorted out my system when my dist. rotor broke during a ride. Is it possible that this link broke (thinking that the car was in accident)?
          If so, is it possible to test it without cutting of the shrink wrap?
          • billybobjoseph
            • 213
            If you have a good ohm meter with some backprobes, disconnect the battery ground then the positive cable. Use the backprobes to poke into the smaller cable on either side of the fusible link; infinite resistance shows the link to have been blown, low resistance shows the link is ok.
            • matias88e30
              • Dec 2009
              • 1110
              never seeing that in my 88is!
              no more boosted m20, 91 318i...
