ICV - Humming?
  • bcausey
    • Jan 2010
    • 316
    ICV - Humming?
    I've tried a few now and as soon as I turn the key there is a slight hum coming from the icv - Before cranking. -Is this normal?
  • whodwho
    • Jun 2008
    • 1547
    That is normal.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • bcausey
      • Jan 2010
      • 316
      Originally posted by whodwho
      That is normal.
      Thanks -
      What would cause a cut out when I blip the throttle? TPS is good, ICV apparently good, DME is good (switiched with another - same idle but then cut out after throttle) - idles strong just doesn't like going past idle very much. Any help is appreciated. Thanks
      • whodwho
        • Jun 2008
        • 1547
        Couple things to check would be check there are no vaccum leaks, check the fuel pressure and make sure it changes with load and check that the AFM door moves freely.
          A hesitation when opening the throttle will be intake leaks or a sticky vane in the AFM.
          • livetheride
            • 444
            would this cause this only at low rpm's? or throughout the whole range?
            • bcausey
              • Jan 2010
              • 316
              Thanks all - I will remove intake and start from there. -
