32mm wrench problem
  • md325i
    • 39
    32mm wrench problem
    In trying to remove the fan for the timing belt change, I bought a 32mm Gearwrench brand wrench from Amazon. However, the end of the wrench must be to wide because I cannot get the wrench to meet the bolt. Any suggestions? From the top, it hits the metal connecting thing connected to two rubber hoses.
    I'll try to see if I can get some pictures in.
    Thanks.
  • FredK
    • 14759
    Yep. Normal 32mm wrenches are too thick to fit in there.
    You'll have to grind it down, or get a headset wrench from a bike shop to get in there.
    • imdashiz
      • Sep 2009
      • 1373
      /thread
      PSN ID: Yourself1
      • hotballs
        • 1155
        I was able to use a generic adjustable wrench which just so happened to be 32mm at the widest point. It was thin enough to fit, or the bike shop headset wrench works as well.
        • Rigmaster
          • 3464
          Buy a cheap-ass wrench, 32mm or 1-1/8" works too, then grind the open end side thin enough to fit in there.
          Then you'll have a tool all your E30 friends will be able to use.
          • ChaseN
            • 709
            I was able to use an unmodified 1 1/8" gearwrench wrench, getting at it from the bottom. I did have to take off two of the water pump pulley bolts though to get it to fit, which worked out nicely since I had to take the pulley off anyways to replace the pump.
            1991 318iS
            1992 911
            2006 330i 6-Spd ZSP people hauler
            Gone:
            1989 M3 S50B32, 6-Spd
            1990 325ix 5-Spd
            • erik325i
              • Jan 2005
              • 3567
              fyi, It's 1 1/4". Not 1 1/8".
              Erik
              • hurttech
                • 237
                ... or get a headset wrench from a bike shop to get in there.
                This, picked one up at a local bike shop for $8.
                • md325i
                  • 39
                  I hate that you just wrote that... I just bought another 32mm headset wrench from Amazon.
                  Damn it. :(
                  Anybody want a 32mm wrench?
