i have a m20b25 nd i wanna stroke it but everything ive read says to use "i" rods and head. can i just use my "is" rods nd head or are they different. any help about this is appreciated
questions abot a stroker
is and i rods are the same 135mm rods. The rods you use depend on the crank and pistons you use.
Look at this for crank/rod combos: http://www.metricmechanic.com/pdfs/m...ne-booklet.pdf
e rods: 130mm
i rods: 135mm 665g
S52 rods: 135mm 565g
ETA = cast 81mm TD drop straight in.
TD = 81mm forged
M52 = forged 84mm, requires simple sleeve for oil seal, perhaps a machined intermediate shaft.
S50 = forged 86mm, requires custom pistons, sleeve for oil seal, a machined intermediate shaft some rods may not clear block.
S52/M54 = forged 89.6mm, requires custom pistons, sleeve for oil seal, a machined intermediate shaft, some rods may not clear block.Last edited by acolella76; 11-08-2010, 03:56 AM.-AlexComment
typoed on your e rods=130mm ;)Comment
