Hey all,
'88 325is here.
I have this rather annoying problem. I turn to position 2 (ignition on) and normally the CEL illuminates and then I'm good to crank. However, now it's not illuminating and thus my car won't turn over. Some other times it will begin to turn over and then just stall. It takes a good 2-5 minutes of sporadic cranking or simply waiting. Once the CEL comes on, car runs like a top.
My question is, and it's really just out of pure curiosity, what could be causing this? I have a less-than-one-year-old CPS installed, a brand new TPS installed, a 173 DME. The only thing I could think of is a bad CPS, but I don't know why it would go bad as the wire isn't even routed through the belts and stuff of the water pump area. I'll check the fuses in a minute and also will investigate the ICV.
If it's any consolation, I noticed the preemptive strike of this problem about two weeks or so ago when the car cut for half a second and the CEL blinked. It did this a couple of times over the next few days, and then the starting problem appeared.
Thanks in advance,
Peter
'88 325is here.
Thanks in advance,
Peter
